Some brake issues...
Old Feb 28, 2006 | 11:49 PM
spearson's Avatar
ok, first off, my back brakes were really bad, didn't work very well. And I had a problem with the pedal going to the floor, having no brakes, and the brake light turning on.
Took them apart the other day because it was metal on metal. Here is what I found:
The two pins in each mounting bracket that are suppose to float, both froze solid, on both sides of the car.
Bleeder valves, oh yeah, not moving.
Caliper was pushing uneven, on both sides.
Parking brake line is frozen.
Both rotors were junk, especially the metal on metal one.
Had to pound the driver side caliper off the rotor.
So, replaced the rotors and calipers and pads and pins.
Bled the brakes extensively, and the pedal is much much more firm when I drive, used to go down halfway before the brakes caught, now it feels good. Somewhat squishy still, I haven't gotten to the front brakes yet.
Here is my question.
I can only replicate this moving forward, not in park. ok, Rolling forward, if I apply a normal amount of pressure, brakes seem to work fine. If I apply a gradual light pressure, the pedal will eventally find it's way to the floor thus turning on the brake warning light, and me not having any brakes until I pump it a couple times. And then it is all back to normal.
A gradual trip to the floor doesn't sounds like air in the lines, it sounds more like a bad MC. Does it sound like a good analysis?
Also, I was doing some searching, and I read that the real calipers won't work properly with the e-brake disconnected. My e-brake is disconnected because the line is completely frozen. Is it important to have? Could I get a clarification?
Steve
Old Mar 1, 2006 | 12:01 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Dang sounds like a nightmare waiting to explode These old 3rd gens are nortorious for problems especiallys after x amount of years. Suggestion is to swap over to a newer brake system from a 4th gen
Old Mar 2, 2006 | 01:39 PM
85LT4Z28's Avatar
Car: 85 z28 and a 97 ford ranger
Engine: 305 carb and a 4cyl pos
Transmission: both have a 5spd
thats weired because i am having ruffly the same problems right now with my 85 chevy camaro... and i think its the master cylinder... i am going to be replacing that today and then i will go through and bleed the brakes now i am having a tough time with seeing how to replace the master cylinder what is the best way to do it and what is the best way to bleed the brakes... any help would be great... and when i get the new master cylinder i will let all of you know how well it works..
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
