lt1 rear with ls1 brakes. do I need axles??
Old Mar 10, 2006 | 12:28 PM
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
Ok so theres a guy on the camaroz28 board that is pretty adament about needing to swap the lt1 rear axles out to ls1 axles in order to run ls1 rear brakes. can anyone confirm this? also from what he said it has to do with the emergency brake hardware. thanks
Old Mar 11, 2006 | 12:27 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
e-brake has nothing to do with the axles.
You may have to shim the caliper a bit since we had a little rubbing when we put LT1 brakes on an LS1 rear.
here is the LS1 brakes on an LT1 rear with LT1 axles,
Old Mar 11, 2006 | 06:24 AM
Car: 91 Z28
Engine: Lt1
I knew that guy didnt know what he was talking about. he said that the LS1 axles are a little biggger and there weas no way to run them with lt1 axles. when you say you had to shim it, what did you use for shims and where did you apply them. thanks
sailtexas186548
Jan 19, 2016 12:21 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
