Are the parkbrake cables the same for 89 9 bolt..
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
and 90 10 bolt rear. Both have PBR calipers.
IM swapping out my 90 high mile 10 bolt, for a low mile 9 bolt. One of the cables was damaged so i might have to use one from the 10 bolt. I pick it up Monday and im just wondering if its going to be a bolt in swap.
The search isnt working but i did read a few things on it. Sounds like its a bolt in just not sure anyone done it?
Mike
Mike
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The cable is the same. Check the following link for part #'s should you require them:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
JamesC
Car: 90 IROC
Engine: 406
Thanks James... thats what i wanted to hear. And for the link theres alot of good info to read thru.
The rear only has 27,000 miles so im excited about the swap.
Mike
Mike
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
