Manual Master Cylinder
Old Mar 14, 2006 | 12:52 PM
JFeaster's Avatar
Car: 1984 Camaro
Engine: 385 SBC
Transmission: Powerglide
Axle/Gears: 4.30
Does anyone have any pictures of their installed manual S-10 master cylinder? Which port is for the front brakes?
Thanks in advance,
Old Mar 19, 2006 | 05:28 PM
JFeaster's Avatar
Car: 1984 Camaro
Engine: 385 SBC
Axle/Gears: 4.30
Anybody? Please help
Old Mar 21, 2006 | 08:35 PM
JFeaster's Avatar
Car: 1984 Camaro
Engine: 385 SBC
Axle/Gears: 4.30
Anybody? Which port (front or back) do you have the front brakes hooked to? The rolling chassis I bought has the front brakes hooked to the back port. I've never seen this before.
Old Mar 23, 2006 | 04:49 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
That is right, I have a manual cylinder of an S10, I thought it looked backwards at first, but that is correct. Rear port to front brakes. Will take some pics of my setup this weekend and post them.
Old Mar 23, 2006 | 09:04 PM
iroczguy's Avatar
You just have to remember that most generally the largest resevior -> the rear in this case goes to the fronts, im sure this isnt always the case but seems to be fairly consistent from what ive seen
-Later,
Greg
Old Aug 20, 2006 | 05:38 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
what all had to be done to get this manual brake set up to work right? thanks
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
codeysabatini
Nov 10, 2015 04:07 PM
camaro1185
Oct 26, 2015 06:51 AM
