13" rotors and 4-piston calipers in stock 16" wheels
Old Mar 20, 2006 | 09:12 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
We found an option for big brakes on a 1987 IROC.
These brakes will clear the stock 16" IROC rims.
Wilwood Forged Superlite calipers.
(click pictures to enlarge)
BMW 750 / 850 rotors. ( 324mm X 30mm ) Almost identicalto C5 Corvette rotors ( 324mm X 32mm ).
The rotor has to be modified to clear the adapter bolts.
Stock IROC rotor on the BMW-rotor.
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Some more pictures.
Old Mar 20, 2006 | 02:57 PM
crazyjim's Avatar
Car: 1989 Firebird
Engine: a monster
holy crap... so wait... does this mean you're using a bmw bolt pattern now? And yes I know they're close to the same but not exactly.
Old Mar 20, 2006 | 03:17 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
This isn't exactly news. Both Ed Miller, and Spohn sell a 13" kit, that uses the Wilwood FBS caliper, that fits stock IROC wheels. Ed also sells at 12.2" kit that clears GTA wheels.
Old Mar 20, 2006 | 10:20 PM
head's Avatar
Car: 1984 MSE #52
Transmission: TH700
How much of the inside of the rotor did you grind away ?? Kinda scary IMO !
Old Mar 20, 2006 | 10:52 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
got a picture of them with a stock wheel on the car?
Old Mar 20, 2006 | 11:36 PM
railroad's Avatar
The rotor and vanes were milled off to a sharp 90* angle and will have severe cracking stress there under heat and load- Kind of scary. They should have been milled at a radius.
Old Mar 21, 2006 | 02:15 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
We tested with a stock IROC wheel too, but I don't have any picture. The BMW has a brake pad that is very large radially. With the Wilwood caliper the inner part of the rotor surface is not used.
The stock bolt pattern is 5x4.75" = 5x120.65mm. BMW uses 5x120mm. It is almost identical. The rotor works fine with the stock bolt pattern.
Milling at a radius is not a problem.
Old Mar 21, 2006 | 02:50 AM
railroad's Avatar
Originally Posted by JoBy
We tested with a stock IROC wheel too, but I don't have any picture. .
13" 6-piston wilwoods under a 16" factory IROC rim with aluminum hubs to boot.
Attached Thumbnails 13" rotors and 4-piston calipers in stock 16" wheels-ab.jpg
Old Mar 21, 2006 | 06:57 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hey there Dean, I was wondering where you went.
The BWM rotor pattern is close enough to work, it's the stud spacing in the hub that needs to be dead on. This is close to what I want to do with GTO rotors. The added height of the rotor will eliminate any need for a spacer and a Wilwood caliper.
Nice work, thanks for the post. Oh yeah...is that a standard or 1LE hub?
Ed
Old Mar 21, 2006 | 09:15 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Ed
Yes, the BMW rotor has a lot of 'backspace' and that will get the caliper away from the spokes on the rim. The 'backspace' is 70mm on those.
I don't know the Camaro option list.
It is a 1987 IROC with drum brakes on the rear. The stock front rotors are 265mm in diameter.
The IROC is a friends car but I am doing the same on my 1984 Corvette.
My stock 290mm x 20mm and the BMW 324mm x 30mm.
Old Mar 21, 2006 | 09:30 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
What do the BMW Calibers look like?
You mentioned that the stock pads were tall.
Seems it would be good to use all the rotor surface area.
Old Mar 22, 2006 | 02:29 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
You can not use them because you have to remove a part of the inner rotor surface with a lathe.
Stock BMW:
Old Mar 23, 2006 | 10:48 PM
contact's Avatar
Engine: sbc 350
JoBy, nice job, thanks for posting this stuff.
You might want to post this at the Crossfire forum.
Just curious, what piston diameters, for the 'vette?,
and how did you choose?
Old Mar 24, 2006 | 09:52 AM
UPSsup50's Avatar
Car: 87 Trans Am, 2002 Ford Focus hatchb
so i saw the z06 ones, they look bad. I am thinking of doing alot to my car but, thinking is one thing and doing is another. lol. I want to put the z06 kit on the front but im still learning and still broke..............
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Eric-86sc
Apr 3, 2016 03:52 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
mustangman65_79
Aug 9, 2015 03:00 AM
