4 wheel disc master and prop info
Old Mar 22, 2006 | 10:51 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Can anyone tell me the proper part #'s of the master and prop for a 4 wheel disc setup on an 87 gta? I switched to disc and need to swap the prop and master. I have a prop and master that has a different part number than the one on my car, so i think it's the right one that I need. i just need to verify thanks.
Old Mar 23, 2006 | 11:02 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I found a website that has all the part numbers cross-referenced by years:
http://www.usol.com/~okfoz/modification/brakes.htm
Old Mar 24, 2006 | 08:55 AM
Car: 1987 GTA
uh oh, that's great info, thanks,...but I see there are many different props and I don't know what year the rear is. It's an austrailian 9 and I thinks it's from a 89 or something. which prop would i use, or how can i confirm what rear it is? Also, it looks like I can use the master that's already in the car. The drum part number is the same for drum and disk after 86-88. thanks!
hectre13
Dec 11, 2023 08:14 AM
Ducati900ss
Sep 2, 2015 09:05 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
