Question ALUMINUM Drum third gen
Old Mar 26, 2006 | 06:58 PM
sleeper383's Avatar
Car: 1984 Camaro Z28
Engine: 5.0L
Transmission: Heavy duty TH700R4 B&M shifter
Axle/Gears: BorgWarner 9 bolt Ratio 3.45
When Third Gen F-body came in 1982 ther was a option for aluminum drum brake for the rear end, (weigth saving) what was the RPO code and how long GM offer this option for third gen F-body.
I khow GM offer aluminium drums on other GM car line up in the 80 years but witch one exactly ?
Thank's for any advice.
Old Mar 27, 2006 | 08:54 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I know a good number of the Turbo Buicks got them and I've seen them on several Monte Carlos in the junkyards. They're great because they're rotating AND unsprung weight. I've seen gains of almost a tenth by just putting aluminum drums on the car.
Old Mar 28, 2006 | 03:47 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
That sounds crazy, they must have done other mods at the same time. It is only weight savings and possibly better heat dissipation.
Old Mar 28, 2006 | 06:17 PM
Dialed_In's Avatar
no, that's the only change. Did you see where I said, "...by just putting aluminum drums on the car"? I dug out the timeslips from that day,it went from 13.98 to a 13.90, so it's actually .02 which is almost a tenth
Old Mar 28, 2006 | 07:35 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The RPO code was J42. I have aluminum drums on my '92 GTA. I know Buick LeSabre's from the mid-80's also used them.
Dropping from 13.98 to 13.90 is .08 seconds not .02.
Old Mar 28, 2006 | 09:08 PM
Dialed_In's Avatar
Sorry, typed the wrong number. Who are you? Internet math police?
Old Mar 28, 2006 | 09:47 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I had a stock 82 sports coupe with zero options and it had the aluminum drums
Old Mar 31, 2006 | 01:26 PM
sleeper383's Avatar
Engine: 5.0L
So why my 1984 V6 Sport Coupe came from the factory with iron drums ????
Do you have V8 in your's
Old Mar 31, 2006 | 01:53 PM
sleeper383's Avatar
Engine: 5.0L
You are right man look what have got with the RPO Decoder with the option J42
"J42 BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, ALUMINUM"
Now what was the years GM offer this option on Thirg Gen F-body's
I personaly saw these drums on 82, 83, 84 and 86 Camaro and IROC-Z
you have aluminun drum on your 92 GTA so i assume GM offer this option for
all the years of the Third Gen Camaro and Firebird
Anybody have other info.
Old Mar 31, 2006 | 05:15 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It had the infamous 4 banger
Vintageracer
Jan 10, 2020 05:33 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
redmaroz
Aug 16, 2015 11:40 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
