rear disc brake pads, anyone have a part number?
Old Mar 26, 2006 | 08:44 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Looking for a set of rear brake pads for the older style calipers. All the local parts stores can come up with is a set for the PBR brakes. Anyone have a part number or photo of the right pads?
Old Mar 26, 2006 | 09:29 PM
Guest
Guest
Posts: n/a
Use the same ones as on the front, just dont run anything with a hard compound or they wont do a single thing unless you get them hot from numerous hard stops. The only difference front-rear is one end of the pad has a portion of the tab for the squealy warning tab cut in half. They will fit though without modifying a thing.
If the places you are going cant find the right pads... I'd be real worried. Thats pretty stupid. IIRC the actual rear pad number is 7070e, I forget the D number but I saw a D202 so thats probably it. The fronts are 7070 and the D is D154, either will work on the rear. BTW almost all that came from memory and I havent sold parts in 10 years... doesnt say a lot for your parts store guys
Old Mar 26, 2006 | 09:31 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Wow, that's hard to believe. There must be some sad part stores in your area.
The rear brake pads most likely will have a 154 in the part number for the early brakes. The later PBR's are 413. Just do a search on www.partsamerica.com, www.autozone.com, or www.napaonline.com for the part number. A Bendix brake pad would be a D154.
Old Mar 26, 2006 | 09:34 PM
Dialed_In's Avatar
Well I went to Advance and the first ones he pulled off the shelf were a set of Fronts. I'll look up the numbers you guys just posted. And yes, the guys at the parts counter are clowns.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
