new pad won't fit. Huh?
Car: 1985 IROC
Axle/Gears: factory
My dad and me were replacing the brake pads on the front disc brakes a couple of weeks ago. Both new pads fit perfectly on the passenger side, but on the drivers' side the inner pad would not go in-between the rotor and the back of the spindle. We carefully inspected the rotor and it's not warped. We took measurements and the spacing between the back of the spindle and rotor are the same on both sides of the car. We even switched rotors and the pads still only fit on the passenger side. The rotors are the same size and everything.
Any ideas as to what the problem could be?
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Did you push the caliber piston back in?
That is what it sounds like.
You can buy a tool to do it or use a large pair of pliers
Car: 1985 IROC
Axle/Gears: factory
yea, it was pushed back in. maybe there's some kind of defect that is really subtle. we were just going to replace the spindle.
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Car: 1985 IROC
Axle/Gears: factory
The outer pad fits perfectly. It drops right into place. Its just a really weird instance I guess. When we find out what the problem is I'll post it. I guess this doesn't happen at all. We checked everything, even filed the pad down to make it slimmer. I just don't understand it.
dbrochard
Sep 25, 2015 04:56 PM
the_hamturdler
Sep 22, 2015 02:59 AM
