Drum to disc swap question
Car: 86 IROC-Z
Engine: LB9
Axle/Gears: limited slip disc
I have an 82 Z28 with a drum rear and I have the rear out of an 83 with a disc rear. When I do the swap what else will I need? Will the brake lines need to be changed or modified?
Thanks,
Will
Thanks,
Will
Transmission: 4L80E/4L80E
Sounds familiar. https://www.thirdgen.org/forums/brak...rear-disc.html
Car: 86 IROC-Z
Engine: LB9
Will
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yep, sounds right. I'd rebuild the calipers with the recall kit or you'll be sorry, thos calipers are prone to failure and freeze up.
Ed
Ed
