Just acquired a rear disc axle
Old Mar 27, 2006 | 09:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
My brother picked up an '83 parts car last year, originally a V6 per the VIN but it had a 305/TH700 in it when he got it. He's cleaning out the yard and offered me the rear from it.
I've never dealt with rear discs before so this is new territory for me. The axle code is 4PY, which indicates a 3.08 posi (a slight upgrade from my current 2.93 posi), assuming that's what still in there. The posi was verified by action, but I haven't pulled the cover yet to verify the ratio.
At any rate, the whole thing is pretty rusty, so I'm looking at taking all of the brake parts apart and cleaning/rebuilding. The axle was cut out of the car after arrival at the junk yard, so the rear hose was just ripped off at the T-block (I'm assuming that's the same thing as my current setup), and the park brake cables are toast. I'm also assuming I need to get a new combo (proportioning) valve, which I don't think will be a problem from MPB. But, I am wondering about those park brake cables. Any suggested sources for them?
Also, did they really put rear discs in V6 cars?
Old Mar 27, 2006 | 10:17 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
you can get parking brake cables at NAPA for about $22 each, also i have never seen a v-6 come with rear disc, except for 98+ years
Old Mar 27, 2006 | 10:23 PM
five7kid's Avatar
A new NAPA store opened up last month a couple of blocks from my house. I'm looking for excuses to patronize them, so I'll check them out. Thanks for the tip.
Old Mar 28, 2006 | 06:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Over the years, many have bitterly complained about the Delco Moraine rear calipers, though I used them for several years without incident. I'd think that most of the remains today would include the rebuild, but I'm unsure.
Product safety campaign 86C28 rear disc cone clutch park brake adjuster.
1982-86 Chevy Camaros with rear disc brakes (RPO J65) and manual transmissions.
Down the road, here's something to consider:
https://www.thirdgen.org/forums/show...hreadid=246768
JamesC
Old Mar 28, 2006 | 11:07 AM
five7kid's Avatar
For now, rebuilding the stock will be the course. This summer 14" slicks will be mounted on certain Friday evenings, so the larger brakes probably wouldn't be compatible with the 14" rims.
I pulled the cover and confirmed the posi & gears. No pinion leakage, the unit seems tight & quiet. The gear lube was probably the original '83 fill, but no excessive wear is evident.
I've located caliper rebuild kits & pads, a lot of work ahead before it's ready to install.
Old Mar 28, 2006 | 11:41 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You can still get the recall kit from GM Parts Direct which is essentially a rebuild kit. About $40 shipped and you're sure you're getting the upgraded pistons. I did mine over the holidays last December when I swapped in a 3.27. If you'd like the part number I can hunt it, unless you're already committed or got a better deal on another kit.
Old Mar 28, 2006 | 11:55 AM
five7kid's Avatar
I haven't purchased anything yet, so yes, the p/n would be helpful.
Old Mar 28, 2006 | 12:14 PM
naf's Avatar
naf
Part Number: 18019028 from GM Parts Direct, listed as "Actuator" and included parts for both rear calipers, pistons, springs, seals, etc.
Good luck with the rear end swap. I did a one for one once in less than six hours, then later that night my buddy came up with the idea of using a creeper to maneuver the rears around.
Old Mar 28, 2006 | 03:00 PM
five7kid's Avatar
I used my tranny jack the last time I switched it out. Took about 4 hours.
for the p/n.
Old Mar 28, 2006 | 04:41 PM
naf's Avatar
naf
Four hours is pretty good, but was the one you swapped in still attached to the back end of a camaro?
Old Mar 28, 2006 | 05:49 PM
five7kid's Avatar
Oh, well, I ate dinner within that 4 hours as well. . .
Old Mar 28, 2006 | 07:41 PM
JamesC's Avatar
Poseurs. I did it in three hours--and I cooked dinner, washed the clothes and walked the kids 10 miles to school barefoot, uphill both ways.
JamesC
Old Mar 29, 2006 | 01:13 PM
five7kid's Avatar
Classic Industries lists their cables for '83-'87 as "LH Rear w/ Disc First Design" and "RH Rear w/ Disc 2nd Design".
What are "first design" and "2nd design"?
Old Mar 29, 2006 | 01:41 PM
JamesC's Avatar
I checked here and didn't see a design difference, in an 85, at least--In later models, 89-92, the difference seemed to be in length:
http://www.rockauto.com/
JamesC
Old Mar 29, 2006 | 06:10 PM
five7kid's Avatar
WAGNER Part # F123943
Rear; RH; w/Rear Disc (2nd Design) {Parking Brake Cable}
WAGNER Part # F108757
Rear; RH; w/Rear Disc (1st Design) {Parking Brake Cable}
WAGNER Part # F123942
Rear; LH; w/Rear Disc {Parking Brake Cable}
First blush I'd say it has something to do with the rotor diameter. But, looks like I'd better get it figured out before ordering.
Old Mar 30, 2006 | 05:21 AM
JamesC's Avatar
82-88 the rotors were all 10.5. 89-92 some (the PBR's) were 11.7, IIRC. Here's info I located on the Camaro Parts and Illustration cat: Bracket, Prk Brk (1983-84) 1st design--7.25mm diameter attaching hole, (1984-90) 2nd design with a 7.01 attaching hole.
JamesC
Old Mar 30, 2006 | 08:34 AM
five7kid's Avatar
Thanks. That helps clarify things.
It's frustrating when year-specific differences are lumped together on a parts system that asks up front for the year.
Old Apr 3, 2006 | 07:15 PM
five7kid's Avatar
Wow, I just check Master Power Brakes for the combination valve - $100!
Hopefully someone has one (SAE threads) that they can part with.
jaridjohn
Jul 8, 2024 03:49 PM
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
