'89 PBR ROTOR SWEPT AREA
Old Apr 14, 2006 | 05:42 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Good day all, I have finished my rebuild of my pbr setup and now things don't look right.....
The amount of pad sweeping seems much smaller from what normal pad sweep should be ie: the front rotors Here is a pic.
The calipers are home rebuilds the pads are raybestos PDG-413M and rotors are Raybestos 6995/D17356. The brake appear to work as seen, but why so little pad area? thanks
Old Apr 14, 2006 | 06:01 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Here is a picture of the pad sweep on the 11.655 dia rotors.
Old Apr 14, 2006 | 07:41 PM
bummer you did not add the pic. I looked at a friends car last night, the only other disk car on okinawa, And his were much better than mine...
Oh and ignore the rims, new tires take a 7-10 days to get here, and he just had a blowout. These are my original junkers
Anymore input?
Old Apr 15, 2006 | 06:32 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Looks to me like the caliper is moved out away from the rotor further than it should be but I don't see how that could happen, they only bolt on one way. Any chance these are Baer rear carriers which could use a larger "Plus 1" rotor that they offer?
Without seeing it up close, this is all I can offer.
Ed
Old Apr 15, 2006 | 07:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you sure those are 11.6" rotors?
Old Apr 15, 2006 | 07:25 PM
gimme a sec. I'll run out and take a new pic... without rim
Old Apr 17, 2006 | 01:39 PM
DJP87Z28's Avatar
Another picture of 11.655 PBR rotor.
tyeo098
Nov 30, 2015 06:27 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
