perfomance friction brake pads are they any good?
Old Apr 16, 2006 | 09:26 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I picked up a set of carbon metalic brake pads a few years ago for the front and have yet to put them on, i was wondering what you could tell me about them? will they hold up? stop well? thanks
Old Apr 17, 2006 | 12:52 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I had them and they sucked when cold. These were the non Z-rated pads BTW.
Old Apr 17, 2006 | 06:32 AM
BLACK Z's Avatar
Car: 86 Z28
How long did it take to warm up? when they got warm how did they work? what was it like when they where cold? thanks
Old Apr 18, 2006 | 01:03 AM
It took a few miles to warm up. When people cut me off, i'd put the pedal all the way to the floor and it would stop, but it was a hair raising experiance. When warm, ok, but liked to lock up. I wouldn't recommend them.
Old Apr 18, 2006 | 11:55 AM
Jeremysyty's Avatar
Just threw a pair of Z-Rated on the TA for a track day. They worked really well, no weird lock up or anything. I didn't push them that hard, the stock 10.25" would fade fast after a lap or so. I ran the others on my old Typhoon and never had any issues either. Lots of dust though.
Old Apr 18, 2006 | 08:19 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
PF Z-rated pads work for me on all four corners. Warm them with a few stops coming out of the driveway and no problems. What I like is no noise & no brake dust. Just put my second set on and my only compliant is the price increase for the PBR pads for the rear since my last purchase five years ago.
Old Apr 22, 2006 | 09:51 AM
BLACK Z's Avatar
Car: 86 Z28
I am unsure which ones I have I know they are carbon metalic, I have had them ont eh self for a while now.I will have to go dig them out and take alook.
Old Apr 22, 2006 | 01:17 PM
DJP87Z28's Avatar
[QUOTE=BLACK Z]I am unsure which ones I have I know they are carbon metalic, I have had them ont eh self for a while now.I will have to go dig them out and take alook.[/QUOT
Their are two types- Reg PF carbon met. & the Z-Rated Met which I use. No brake dust and no problems stopping even if cold. My brake pedal never get near the floor in even panic stops.
Old Apr 22, 2006 | 05:48 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
same here they suck for a street car will never buy them again. i put them on the wifes car and same thing they sucked. after they wore out i installed a standard set of semi metalic pads night a day difference.
Old Apr 22, 2006 | 07:15 PM
BLACK Z's Avatar
Car: 86 Z28
SO you are saying that the non Z rated take awhile to warm up and the z rated don't?
Old Apr 24, 2006 | 09:00 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I run the z rated with the pbr baer kit. Buy at auto zone with lifetime warranty
Good results on track day car.
Very Rotor Friendly
Make sure your burnish them before track use. When the pads de gas you have no brakes. Full pedal but no friction.
After break in they are fine.
Old Apr 29, 2006 | 11:47 AM
kalel21's Avatar
Car: 91 Z28, 86 Z28
Engine: 5.7 TPI, 5.0
Transmission: 4L60E/transgo shift kit
I had the Raybestos Quiet stop and I noticed they put alot of dust on my wheels so I changed to the PF Z rated. Alot better on stopping power and made less dust.
Old May 5, 2006 | 09:59 AM
BLACK Z's Avatar
Car: 86 Z28
So the non Z rated pads are junk?
Old May 11, 2006 | 07:41 AM
BLACK Z's Avatar
Car: 86 Z28
Please keep it coming.
Old May 27, 2006 | 06:29 AM
TTA345's Avatar
I have owned both versions (on many cars, my T-Bird, GN, Camaro, F150, etc...) and always found them to be excellent. Sure, it takes a little longer to warm them up, but they have to because they are a better compound for braking performance. Bottom line is, if you want the increased performance from the braking, the trade off is they take a little longer to warm up than the crappy non performance pad will. I can't imagine complaining about it, it would be like whining about an IROC riding harshly. lol. Get the pads, you won't be disasspointed. The Z-Rated pads are the real performance pads (Severe Duty), but their regular version works great too.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
