ls1 e-brake cables
Old Apr 18, 2006 | 01:48 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
ls1 e-brake cables
Hey gang, I installed a ford 9 rear in my 89 iroc with 2002 trans am ls1 rear brakes. Has anyone figured out what to do for e-brake cables. My 89 came with a 9 bolt borg warner rear which I have put in my 92 purple haze z28 and I used the 9 bolt cables with it since they would not fit the ls1 set-up. By the way I got the 9 ford housing and adjustable kit from autoweldchassis.com They make great stuff. Any help on the e-brake cables will be greatly appreciated since that is one of the last things I have to fix.
Old Apr 18, 2006 | 06:09 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
I followed the advice on these threads:
https://www.thirdgen.org/forums/brak...backing+plates
https://www.thirdgen.org/forums/brak...APA+cables+LS1
and flipped the backing plates side-side. Just cut the cable supports so they bolt on
the opposite side LCA brakets, and used latemodel PBR ebrake cables from NAPA.
(p/n 94264, have to ream the slots on them slightly)
http://www.eecis.udel.edu/~davis/z28...ls_brakes_web/
http://www.eecis.udel.edu/~davis/z28...t_install_web/
hth
mike
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
