LS1 questions
Old May 20, 2006 | 01:33 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
LS1 questions
i am sure this info has been covered, but i searched and could not find it. i even read the first 3 chapters of the FAQ...
so far i have two calipers, pads, two bracket things (pictured) and two hubs from a 98+ TA.
my question is this: can i use these hubs or do i need to get my current discs machined down into hubs like most people do? also, what are the gear teeth on the back of the 98+ hubs for? if i am able to run these hubs would i be using different wheel bearings? and lastly, are there any more brackets that i will need?
thanks guys, i know it sucks answering the same questions over and over, but i realy did search i swear.
anyway, here is a photo of what i have so far. i recieved this stuff as trade for hauling a friends camaro to the junkyard
Old May 20, 2006 | 09:36 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Let me clear some things up for you..what you have is 2 LS1 calipers, a pair of C5 adapter brackets, and turned down hubs from an ABS equipped S10 or something, they aren't '98+ hubs. You can use them in place of the hubs you will need but you'll need different mounting brackets.
Sent PM.
Ed
Old Jun 17, 2006 | 06:41 PM
Xophertony's Avatar
Axle/Gears: n/a
i hate to be a pest, but i still have one question.. what wheel bearings will i be running with the correct hubs EbMiller is getting me (LS1 hubs i assume?)?
Old Jun 19, 2006 | 02:40 AM
ebmiller88's Avatar
Stock set 6 inner and set 34 outer (Timken).
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
