side by side pics of stock c5 and c6 Z06
Old May 25, 2006 | 06:34 PM
luke j's Avatar
Car: '87 GTA hardtop, '86 IROC hardtop
Engine: 385 DFI, 350 carb
Transmission: T-56, T-5
Axle/Gears: ls1 torsen 10-bolt, 9-bolt disc
side by side pics of stock, c5, and c6 Z06
here are some side by side pics of my brakes and my friends c5 brakes as well as a stock c6 Z06 setup.
Old May 25, 2006 | 06:35 PM
luke j's Avatar
plus two more
Old May 25, 2006 | 08:12 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
drool.
so whats the chances of me fitting that c6 under my stock 15 inch rims ?
Old May 25, 2006 | 09:18 PM
luke j's Avatar
I'm going to go with slim to none.
Old May 25, 2006 | 11:42 PM
RSChris's Avatar
Car: 1990 Camaro RS
THOSE Z06 BRAKES WOULD BE NICE UNDER THE Z06 REPLICA WHEELS I'M GOING TO USE WONDER, WHATS ALL NEEDED TO KIT THOSE TO FIT?
Old May 26, 2006 | 07:17 PM
PrinceCharmmin's Avatar
Car: 91 RS Camaro
I hear that the new Z06 calipers will bolt on to the C5 set up with out any problems.... I have heard that but I have not tried it yet tho....
Old May 26, 2006 | 09:54 PM
luke j's Avatar
that is correct, the setup in the pic was for a g-body, but it was still a direct swap. the only thing I can see that might be an issue is wheel clearance. the front of the caliper sticks out past the hub face 2". make sure your wheel has enough depth for it.
Old May 26, 2006 | 09:59 PM
AJ89Irocz's Avatar
Car: 1989 Camaro Iroc-Z
Axle/Gears: 2.77 Posi
So would the brakes clear if using C6R wheels? Those would definatly look bad behind a set of nice rims, might have to skip the C5 conversion for them!
Old May 26, 2006 | 11:13 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
so what would be the smallest rim that would work for the Center setup?
Old May 28, 2006 | 07:48 PM
luke j's Avatar
I am pretty sure thet you need at least a 17" to clear the c5 setup, try a search, there are plenty of threads on that swap.
Old May 29, 2006 | 06:22 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Those look like fun.
17's at least for the c5 brakes and even then, some of them don't work depending on offset.
Old May 30, 2006 | 03:08 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Geez,
Just looking at those pics makes me feel small and inadequate just like my only car left with stock 10.5 inch brakes.
lol
Hope the price drops on them bad boys a little more and now we're talking.
later
Jeremy
Old May 30, 2006 | 11:55 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The C5s need at least 17"s, the C6 setup will need a bit more, I expect at least an 18" wheel for those. A good rule of thumb is a wheel that is 3" larger in diameter than your rotor but isn't exactly true in this case.
Ed
Old May 31, 2006 | 12:31 AM
LT1LE's Avatar
Car: TWO 1992 CAMAROS 1 Z28 AND 1 B4C
Engine: 1 LQ9 AND 1 LS3
Transmission: 1 T-56 AND 1 6L90
Axle/Gears: 1 4.11 AND 1 3.31 (DANA 44)
SOME 17" WHEELS WILL WORK WITH THE PROPER SPACER. MOST 18" WHEELS WILL CLEAR THE CALIPER BUT SOME WILL REQUIRE A SPACER.
Old May 31, 2006 | 07:34 AM
luke j's Avatar
I have tried to fit a SLP 3rd gen ZR-1 wheel, the caliper hit the step on the inside of the wheel. there is a step right in the middle of the wheel for mounting the tire. there was about 3/4" to 1" of clearance between the rotor and wheel.
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
zayne0
Aug 24, 2015 07:22 PM
GMC-YA
Jan 8, 2005 12:41 PM
GASGZLR
Theoretical and Street Racing
Jun 17, 2004 10:05 PM
