Baer brake kits
COTM Editor
Baer brake kits
I was wondering if any of you guys had strong opinions on these brake kits other than the cost. I know that nowadays there is a lot of options for brake kits, but for some reason I feel partial to the baer kits. Maybe someone should tell me why not to do it.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I bought one for my Formula. Kit was nice. Yes I could have saved and pieced stuff together, but they came all assembled. All i had to do was place on BJ and bolt in.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I have both plus and minus to the Baers:
PLUS: They have some of the best rotors available. DBA Austrailia makes rotors for Baer and I have both Baer rotors and DBAs in the shop and they are VERY thick and can handle the heat no doubt. Here's a comparison I did with a stock and Baer rotor. Pics speak louder than words:
https://www.thirdgen.org/forums/brak...highlight=baer
MINUS: Cost. Baer has raised their prices a LOT this year, both on rotors and complete kits. Thunder lists the 13" Claw Track kit at $1231.99 before options and the spindle core charge. I can do that kit for less than $900 all day long, all in one kit as well, saving you $331.99 to spend on other parts.
Baer has a look that some guys need to have but you can get zinc washed and drilled rotors other places as well. It's personal preference I guess.
Ed
Ed
COTM Editor
Ed, thank you for the info. Sounds like from the searches I have done you are the man who knows. I am the type of guy that wants the name, but the quality also looks exceptional. I talked with a guy @ Baer (Johnny) that was telling me that the 91-92 camaros do not need a adjustable proportioning valve when swapping drums to disc in the rear. From every thing I have researched this is completly wrong. I made him put me on hold and he talked with the tech dept., and they said yup, no apv only on 91-92. They said the rear brake bias is enough on these two years?
I am leary about this. I did order the brake kit - Track pro w/ 13" two piece rotors in front, and Track w/ 1 piece rotors in rear. Had them polish the calipers, slot, drill, and zinc the rotors. I have not ordered the prop valve do to what they have told me, but maybe they are completely wrong an I should just order now.
Thanks again.
I am leary about this. I did order the brake kit - Track pro w/ 13" two piece rotors in front, and Track w/ 1 piece rotors in rear. Had them polish the calipers, slot, drill, and zinc the rotors. I have not ordered the prop valve do to what they have told me, but maybe they are completely wrong an I should just order now.Thanks again.
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Originally Posted by BADNBLK
I talked with a guy @ Baer (Johnny) that was telling me that the 91-92 camaros do not need a adjustable proportioning valve when swapping drums to disc in the rear. I made him put me on hold and he talked with the tech dept., and they said yup, no apv only on 91-92.
Get a 1LE combo-valve for that set-up, you'll be fine...
Thanks again.
Good luck with your project!
Ed
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
red90IROCls1
Aug 25, 2015 06:56 AM
