My Camaro, Rear disk?
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
Hey juys I have a 1982 Camaro Berlinetta LG4. I'm looking to upgrade my breaks with rear disk. Are there any third gen Camaro that came stock with them. I was thinking that if there is would it be a good idea to go to a jy, find one and takes the brakes.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
do a search, theres plenty of info, you can do it look for 89 and up brakes as the calipers are better, you have to modify the axle housing to mount the backing plate, theres a tech article on this, i'm in the process of putting 98+ brakes on my drum rear.
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Car: a car being parted out
Engine: blown up
Transmission: in peices
Originally Posted by 86camaro383
If you want a direct bolt in, get one from a third gen. IROCs all came with 4 wheel disk brakes (im pretty sure) and GTAs did.
at least my 89 does.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
