cant get brake pressure
Old Jun 2, 2006 | 11:45 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i have bleed my brake brakes twice, the brake pedal is hard after bleeding, but when i start the car and press the pedal, it goes to the floor with no pressure. theres no leaks anywhere. is it the master cylinder bad?
Old Jun 3, 2006 | 12:40 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I hope you didn't let the MC go dry during the bleed x2?
Old Jun 3, 2006 | 01:19 AM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
two things, one side of the mc did go dry, the mc is divided into two parts, the rear reservoir one did go dry, dont know how but it did. second, i now realized i think, i put the caliper on the wrong side, its the c6 caliper and the bleeder screw is towards the bottom, so i think air is still trapped in the caliper, due to the bleeder screw being on the bottom and so air is trapped in the upper part of the caliper. i hate it when i do stupid things like that.
Old Jun 6, 2006 | 06:34 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BRAKEING NEWS
OK you need to re-bleed. Use an automatic feeder into the MC.
Your MC will not only never go dry but it will be topped off
for you when you finished.
Happy Racing!
“If people drove any slower
they’d be going backwards.”
Old Jun 6, 2006 | 07:22 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Letting the system go dry was bad...you just need a THOROUGH bleeding, it may take a while. The dealer can pressure (or vacuum) bleed the system for about $35 or so.
Ed
Old Jun 7, 2006 | 07:15 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
If you choose to do it yourself unbolt the master and get it level, loosen the outlet tubes, and let it gravity bleed making sure it doesn't go dry again. Then tighten the lines, refill, and crack open all four bleeders and let it gravity bleed again. After all four bleeders are dripping tighten them, bolt the master cylinder back on, and bleed in the normal sequence.
Old Jun 10, 2006 | 12:32 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
ah man, since you're car is probably in you're backyard or something ,you're going to have to manually bleed it, get alot of brake fluid and a buddy too. bench bleed the m/c and then bleed the entire system . dont worry everyone makes mistakes
Old Jun 10, 2006 | 08:00 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
it finally got the bleeding done, it was pretty easy after switching out the calipers. i bought a 10 ft clear hose and made sure it was higher then the car and slowly pump my brakes, if theres no air in the hose, then i knew there was no air in the lines.
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
