Brake squeal/squeak
Old Jun 11, 2006 | 10:07 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Brake squeal/squeak
What can cause the front right brakes to STILL squeal and squeak?
New ceramic pads
New rotors
New wheel bearings
New front brake hoses
New calipers
And i have personally lubed all the slides/shims correctly. And done it more then once...
It only squeals from the RIGHT FRONT.
Im stumped...bring on the opinions
This is on a 1989 RS Camaro
Old Jun 12, 2006 | 11:46 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
have the pads and rotor honed, worked for my friend. Mines doing the same thing and ive changed everything too. He takes like a pad with little rods sticking out and the rods have little ***** at the end and he goes over everthing. Try it, worth a shot.
Old Jun 12, 2006 | 01:52 PM
Stevo's Avatar
Take it to a shop or do it myself? Is it a tool you can buy? It just takes a layer off right?
Old Jun 12, 2006 | 08:34 PM
Car: 1991 Z28
Engine: SBC
well my friends got a shop, i looked at my work (advance auto) but what we had to hone brakes was nothing like what he had, try taking it to a shop and ask them about it
and yea i believe it takes a thin layer off, if there are any imperfects like glazing or whatever
Last edited by LoudmouthSS; Jun 12, 2006 at 08:36 PM. Reason: Automerged Doublepost
Old Jun 12, 2006 | 08:41 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
resurfacing the brake rotors and pads can work occasionally but if you already have ceramic pads with the proper shims you may have another issue. How thick is the rotor? is it too thin causing the brakes to overheat and glaze or is it a cheaper rotor and doesn't have the proper cooling vanes. You might be surprized but different rotors can have odd vane patterns to alleviate noise.
Are your rear brakes out of adjustment again causing the front brakes to overheat and cause the rotor to glaze?
Old Jun 19, 2006 | 11:57 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I SOMETIMES SQUEAL, LATE AT NIGHT
Remove the pads and coat the metal side
of the pads with anti-squeal compound.
Happy Racing!
If people drove any slower
they’d be going backwards.
Old Jun 19, 2006 | 12:20 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
What brand of ceramics are you using? I sell Raybestos, and they make two grades of ceramic....the Quiet-Stop,
which is allegedly their premium product, and an economy ceramic, which is by far a better pad. I sell 90% to
wholesale customers, and have had only one bad report on the economies, but almost every 'premium' set squeal.
I run Hawk ceramics myself with my C-5 conversion, and am 100% satisfied-yes, they were expensive, but no
dust at all, and very quiet.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
