will 12.5 c5 brakes fit under iroc or gta wheels?
Old Jun 23, 2006 | 08:38 AM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
i wasnt sure about the front fitment.
I know there is a sticky but i wanted a clear and confirmed answer.
speed
Old Jun 23, 2006 | 10:43 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
from what I have read, they should as the 12's have lots of room left.
but I still think it may get a little tight going that big.
Old Jun 23, 2006 | 02:03 PM
Car: 1989 IROC-Z
Engine: 346 LS6
i have gta wheels by the way. is there a confirmation that they fit under those?
thanks
Speed
Old Jun 23, 2006 | 03:31 PM
LT1LE's Avatar
Car: TWO 1992 CAMAROS 1 Z28 AND 1 B4C
Engine: 1 LQ9 AND 1 LS3
Transmission: 1 T-56 AND 1 6L90
Axle/Gears: 1 4.11 AND 1 3.31 (DANA 44)
NO... YOU NEED 17" WHEELS (AND A 1/2" SPACER ON SOME WHEELS).
Old Jun 23, 2006 | 11:21 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
No they will not, now.. a C5 caliper paired with a LS1 rotor will fit though, I've done it.
Ed
Old Jun 24, 2006 | 08:00 AM
Car: 1989 IROC-Z
Engine: 346 LS6
what modifacations are required to put ls1 brakes on c5 calipers? do theyjust swap out? are the spindles the same?
I might buy the whole front c5 setup from a guy... if i do the ls1 rotors what do i need from him?....
calipers
spindles?
what else?
thanks
Speed
Old Jun 24, 2006 | 01:32 PM
ebmiller88's Avatar
You'll have to ask that guy but the calipers will interchange, just use the right pad for the caliper you use.
Ed
Old Jun 24, 2006 | 01:55 PM
LT1LE's Avatar
YOU HAVE TO USE LS1 ROTORS, LS1 CALIPER CARRIERS(BRACKETS), AND C5 CALIPERS.
Old Jul 10, 2006 | 11:46 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Ok so to put it all in one sentence to make sure. If you use the 98-02 Fbody 12 inch rotor, 98-02 Fbody caliper bracket, with a c5 Corvette Caliper you can install them on a car with GTA rims and not have any issues. Just wanna clarify im reading this all right.
skinny z
Carburetors
Sep 29, 2015 11:25 PM
firebirdfreak87
Apr 15, 2013 03:12 PM
Atilla the Fun
Jul 20, 2012 11:10 AM
speedmachine
Brakes
Jun 23, 2006 03:27 PM
