Questions about brake upgrade
Old Jun 30, 2006 | 11:16 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Ok I have a few questions. Been doing some searching/reading on the site. I have a 1989 Iroc. 5,7 TPI. J65,GH3,G80,MX0( 4 wheel disc,2.77 gears,limited slip,4speed auto w/OD) Looking in through the rear wheels,it looks like I have the PBR aluminum calipers(they have the fins on 'em). According to this site,my car should have a BW nine bolt rear with this gear ratio,engine and trans combo. It has a 10 bolt. I thought only the BW nine bolts came with the PBR calipers. I physically haven't removed the rear wheel to measure the rotor size to confirm. Also when I did the rear brakes the caliper didn"t require that it be "screwed in" to compress it,just a clamp. I bought the car from the second owner(car had 12,000 miles on it from 1st owner, traded in, bought by second owner in 1991 and I bought it from him with 78,000 last year) Am I misinformed about these rears and brakes or am I just reading everything wrong. Could this rear have been installed inplace of a BW 9-bolt later in its life? Also how would I go about upgrading the front brake to a "hub"( no castle nuts,cotter pins and packing bearings) design with better(bigger) calipers and rotors.Where can I purchase the parts. I'm running the stock 2 stripe 16" Iroc wheels all around.
Old Jul 1, 2006 | 11:37 PM
remltr's Avatar
Any one? I've done searching and maybe I'm just reading too much into it and confusing myself. Just need alittle clarification. Thanks!
Old Jul 1, 2006 | 11:47 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
with a 2.77 ratio then you have 9 bolt with pbr, 10 bolts have pbrs too, but i believe only on 90-92, not sure if any 89 had them and no pbr was available before 89.
Old Jul 4, 2006 | 06:00 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
i just did a LS1 break swap on the front with parts supplied by Ebmiller on the boards. hes a great guy to deal with and his prices are real fair. check out my cardomain for pics from the swap. its pretty straight forward.
matt
Frozer!!!
Jan 19, 2024 04:55 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
