Rear Brakes????
Old Jul 2, 2006 | 02:14 AM
globalco's Avatar
Rear Brakes????
I have a 92 Z and was told the rear brakes are the same as 1LEs. I have C5/Z06 fronts and would like to go bigger on the rears also.
Question, do I have 1LE rear brakes, if not what about LS1 rears?
I don't see anyone with a rear package, is there one?
Jim
Old Jul 2, 2006 | 02:37 AM
Pat Hall's Avatar
Yes, your rear brakes and 1LE rear brakes are the same. LS1 brakes aren't any bigger than the ones you have right now. The only advantage to the LS1 brakes is that they have a better designed internal parking brake setup. Probably the only way you could get bigger rear brakes would be to go aftermarket, such as Wilwood or Baer.
Old Jul 2, 2006 | 02:38 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
the rear disks on 89-up cars are PBR calipers. Which are the 1LE brakes. Ls1 rears can be put on the rear although I don't know exactly what needs to be done as I just swapped in the entire rear, it gave me a brake and gear upgrade all in one. Ed "ebmiller88" sells a package to upgrade the rear brakes. to whatever brakes you want I believe haha. And it's alot cheaper than aftermarket, also parts are readily available. He may ring in soon.
Old Jul 2, 2006 | 06:20 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Here...as said above, '89-92 rear discs on all cars are 1LE spec, all the same. I do offer complete rear disc upgrades that will bolt on, soon to offer totally bolt in LS1 rear discs as well:
Yahoo! Photos - taramiller72's Photos - PBR rear brake kit
Ed
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
