caliper to rotor clearance
Old Jul 7, 2006 | 03:23 PM
net_coma's Avatar
How much clearance inboard and outboard do I need between the caliper and rotor with PBR calipers. Also in bolting the caliper to the backing plate, lock washer or no lock washer....loctite or should the bolts have self locking threads? Just about have this thing back together and don't wish to discover later that I was blessed with a moment of the dumbazz syndrome.
Old Jul 7, 2006 | 06:39 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
About 1/16"-1/8" per side or whatever centers the carrier over the rotor. Just make sure the rotor is tightened down with a lug nut or two so it won't move when you get the spacing down;
No lockwashers, just a bit of red threadlocker on the threads that engage the guide pins;
Hope all is going well with the setup.
Ed
Old Jul 8, 2006 | 02:25 PM
net_coma's Avatar
Brakes are all together, just have to replace the calper mounting bolts to achieve full thread engagement and tweak centering on one.
Old Jul 9, 2006 | 05:21 AM
ebmiller88's Avatar
You'll only get about 1/4" of thread engagement on the guide pin bolts in case you think that's odd...I thought they'd go in a bit further myself but this is not the case. If you have that much and add some red threadlocker, you're good to go.
Ed
PS: I BROKE 5000!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 9, 2006 | 06:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
And all of them were on the brake broad .
JamesC
Fanatic1074
Oct 3, 2022 05:57 AM
91 SrS
Oct 7, 2015 04:32 PM
loud91rs
Oct 5, 2015 10:05 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
