9 bolt rear disc brakes
Old Jul 17, 2006 | 12:48 PM
kyle88transam's Avatar
Car: 1986 Trans Am
Engine: soon to be a iron block 5.7 lsx
Transmission: 4l80e
Axle/Gears: 9 inch
I have a 9 bolt rearend and disc brake calipers. The Question I have is Do you have to have the emergency brake equipment on the calipers for them to work properly? I rebuilt the calipers and they looked good but since they have to twist back in do they need the counter weight and spring to work. I tried to use front calipers since they use the same pads and mounting location but the piston bulge will not clear the bracket. Any help would be appreciated because then ten bolt has about 1" of play without the driveshaft moving.
Old Jul 19, 2006 | 08:58 PM
Car: 1986 Trans Am
Transmission: 4l80e
Axle/Gears: 9 inch
bump
Old Jul 20, 2006 | 04:32 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, the e-brake was used to adjust the calipers.
JamesC
Old Jul 22, 2006 | 06:52 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
On your '88, yes you need the e-brake stuff for the calipers to work and adjust right. Not an issue with '89 and up rear discs.
Ed
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
