Brake gurus.....brake upgrades and GTA wheels
Old Jul 22, 2006 | 10:37 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
It seemed for the longest time Ed's C4 non hd upgrade was the best way to go but you mad scientist types seem to come up with something new regularly. Sometimes it is a good thing to be slow on your upgrade, those that upgraded only to have have a newer better, larger option
come along just after can understand.
So what kits will fit under a GTA 16x8 wheel ?
I am not interested in the Wilwood kit , to me that is overkill for the street. Thanks..............
Old Jul 22, 2006 | 11:23 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
As far as I can tell Ed's C4 kit is about it gor GTA wheels though the LS1 may be a possibility.
Old Jul 22, 2006 | 02:34 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
So far, my 12.2" Wilwood setup, 12" C4s, and 12" LS1s..maybe 12" 1LEs..to my knowledge that's it.
Ed
Old Jul 22, 2006 | 04:44 PM
Stephen's Avatar
Car: 87 GTA
I'm still trying to find a good brake upgrade for my '87 GTA. I PMed Ed, but no response. Anybody got a good solution, for GTA honeycomb wheels? I'm not willing to ditch my honeycomb wheels for anything.
Not unless I found a cheap way to make 17" honeycomb wheels. In other words, it'll never happen.
Old Jul 22, 2006 | 06:50 PM
ebmiller88's Avatar
I just got back from a week's vacation at the beach so I'm once again backed up on PMs and e-mail responses, please be patient and I'll get to you. The above mentioned solutions are all great but will depend on your budget and braking desires, those will range from $700 or so to $1350.
Ed
Old Jul 22, 2006 | 06:56 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
will the c4 hd brakes fit under gta wheels?
Speed
Old Jul 22, 2006 | 07:02 PM
ebmiller88's Avatar
No. The issue is that the GTA rim casting has an inner lip that contacts the caliper on most of the larger rotor setups. I have a lot of pics of that in various threads but I can tell you that they won't fit that wheel. The problem is the casting.
Ed
Old Jul 22, 2006 | 09:23 PM
Stephen's Avatar
Car: 87 GTA
No problem. I'm in no hurry. I just assumed the PM didn't go through.
Lemme know what options are available, along with prices.
Old Jul 23, 2006 | 03:09 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
othger then the willwoods the LS1s seem to be the "gigger better" option for the GTA wheels. since you are looking for brakes for street use that should be plenty enough anyway.
i am about halfway through the parts aquisition process of this swap. unfortunatly the GTA wheels i was going to buy (my GTA has aftermarket 15" crap on it) are not quite as for sale as i originaly thought. and until i get a set of 16"s i can't put the Ls1s on anyway..... i don't know if they will fit behind a 15" wheel, but i am not about to swap and then find out i can't drive my car until i get wheels.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
