Diffrent rotors solve my problem?
Old Jul 23, 2006 | 11:39 AM
EvoByDarwin's Avatar
Well Ive tried to put a set of 18" wheels that I had on my 99' SS onto my '92 RS only to find that the hub (more so where the dust cover goes on to protect the wheel bearings) is too large a diameter and sticks out too far for the front wheels. The rears fit fine even with a 295/40/18. My question is, is there a cheap way I can fit different rotors on the car that have more of a 4th gen style hub?
Any help is greatly appreciated.
Old Jul 23, 2006 | 11:58 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You didn't use spacers?
Old Jul 23, 2006 | 12:04 PM
No need on the rears, the fronts doesnt look like I'd need spacers but I cant tell because I cant get the wheel on the lugs due to the hub being a larger diameter than my wheel. FYI, the fronts are only 245/35/18's.
Old Jul 23, 2006 | 12:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You need spacers.
Old Jul 23, 2006 | 12:19 PM
You need spacers.
I dont think you understand my problem. The hub, that the dust cover attaches to is too large and my wheel opening that allows that hub to come through is physically too small. For example, my 99 SS doesnt have a hub that sticks out, its almost flush with the rotor hat so they work on that application, Im trying to figure out if theres a rotor that I can retrofit onto the '92 to solve my problem.
Edit: If your saying I need spacers to push the wheel out, thats not a solution as it would have to push the wheel out so far that the lugs wouldnt reach the wheel.
Old Jul 23, 2006 | 12:33 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i suggest posting pics, it would be easier to see and understand what your talking about
Old Jul 23, 2006 | 12:46 PM
If you'll notice the area in the rotor picture with the red line, thats the "hub" that Im refering to that is too large of a O.D. to fit inside of the wheel of which Ive also highlighted with a red line. Hopefully that clears it up.
Old Jul 23, 2006 | 12:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm not talking about slip-on spacers.
The wheels you're trying to use have a different backspacing than a thirdgen wheel. Even if you could get them to mount, they'd be tucked under the fenders too far. You need spacers.
Old Jul 23, 2006 | 12:59 PM
Oh wow, cant say that Ive ever seen anything like that. Where would one go about finding those?
Edit: wow I found em, trick looking pieces and the prices to match.
Old Jul 23, 2006 | 01:01 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
What we're trying to tell you is that 3rd and 4th gen wheels have totally different backspacing and offset and that you cannot run 4th gen wheels on a 3rd gen without spacers, posted by Apeiron above...can't do it.
I recommend Skulte Performance Designs - Skulte Performance Designs, great guy to deal with.
Ed
Old Jul 23, 2006 | 01:30 PM
Ed
I did some research before I posted and I understand the 3rd to 4th gen differences, but these aftermarket wheel have a different offset than the stock 4th gen wheels (hence why the rears fit with out any spacers or modifications). The fronts actually look like they would be the correct offset, they just wont accept the 3rd gen hub.
Old Jul 23, 2006 | 01:44 PM
ebmiller88's Avatar
Ahh, OK then. Looks like you'll have to take the wheels and have the center hubs bored out or, what I'd do, take the rotors off, remove the studs, and have the hub snout machined down to fit the wheels...much cheaper than my first option.
Ed
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
CORV3TT3
Aug 23, 2015 11:26 AM
