ls1 master cylinder in an 86 iroc? help!
hey guys i have upgraded my fornt brakes to 2004 zo6 brakes and will be doing the rear soon. id like to change the master cylinder but i hear the beake line fittings are different from 82-86 vs. 87-92. i see most people make new lines to the prop valve......but will lines fit with ls1 master cylinder to my prop valve? what are my options guys?
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Here is a thread I started awhile back. I did the LS1 master swap. It wasn't too hard but I di end up making my own lines to the prop valve.
https://www.thirdgen.org/forums/brak...inder-not.html
COTM Editor
Maybe its a dumb question, but what are the benifits of the LS1 master cylinder?
Well it is in part to have a cleaner look and a master cylinder res cap that is easy to close and open. The main reason is because of the smaller piston diameter. From what I read the piston design and size affects pressure there by affecting clamping force. For some reason a smaller diameter creates more pressure.
Car: 1985 IROC Camaro
I just installed an LS1 master cylinder in my 85 IROC. Bolted right in. I had to bend the lines a little but that was it. My car had the same metric bubble flares as the LS1. I heard that it was only 82 and 83 that had the american thread fittings, but I dont remember the source. Should bolt right up on your 86.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
I would say a cleaner look.
