Possibly a bad proportioning valve??
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I recently took my entire brake setup off my car and put it on a buddies camaro. I changed everything from the hoses on down. Including spindles and brackets. The works. My car didn't stop very well when I took the stuff off. When I got done with his camaro I took it for a ride to check out my work. I did a couple of quick stops and his camaro stopped like I threw out an anchor. I mean I damn near went through the windshield. So whats the deal?? I change the master on my car cause I though that was the problem. Is it a bad valve or obstructed line or what???? Can I get a new valve somewhere?
backtothe80s
Sep 5, 2015 12:39 AM
