Question on rebuild of rear pbr calipers
Car: GTA 89
Transmission: TH700
I'm in the process of rebuilding my 9 bolt BW with all the attached parts.
After disassembly of the pbr rear brake calipers I found the inside of the piston bore being scratched, the piston itself is scratched too.
The caliper is not leaking, the seals are ok.
My question is: is it better to rebuild the calipers with new pistons and seals or to buy (new) remanufactured ones?
Thanks in advance
P.S. Does someone have pictures of original pbr rear brakes, where the color of the brake parts and the plating of the brackets are visible?
Thanks in advance
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Car: GTA 89
Transmission: TH700
JamesC,
thanks for the link. It seems that most of the parts were painted afterwards.
I'm interested in the surface condition of the following parts when they were new from the factory:
As far as I can see thes parts were not painted from the factory, they look like chromated or zink plated ... I'm not sure...
Can someone confirm?
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The e-brake brackets are zinc coated, the e-brake lever is a dark plated color. I replate both of them zinc and they look great. As for the scratches, I'd use those calipers as cores and get another set...the scratches aren't a good thing.
Ed
Ed
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
hectre13
Aug 26, 2015 08:17 AM
