Rear Disk Differences from 82-02
Old Sep 20, 2006 | 11:57 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I realize that all thirdgen 10 bolt shells were the same with the difference being updated disk brakes in 89. However are the mounts (for the DISK brakes) all the same? Can I bolt 2002 rear disks onto an 82 rear disk 10 bolt? If not, what years were the mounts the same from 82-02? I ask this because as I swap my rear I want 89+ disks and I would like to know if I could settle for an 82-88 disk rear and swap the 89+ disk brakes onto it. Or even better, swap newer (98+) disk brakes to it. I do not want a 4th gen rear.
Andy
Old Sep 20, 2006 | 03:28 PM
tuske427's Avatar
Car: 1984 Trans Am
Engine: 2002 LS1
Transmission: 6 speed
Axle/Gears: 3:73
While I can't say for sure, but what I can tell you is that the Wilwood brakes I bought for my car are listed for 4th gen cars only but they bolted up to my 1984 (disc) rear axle just fine with no modifications. This being said it is likely that they are the same.
I hope this is good news for you.
Old Sep 20, 2006 | 03:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes.
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Sep 20, 2006 | 10:04 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Cool. And when I said 89+ I really meant it, so like 89-2002. They interchange through the whole run?
Old Sep 21, 2006 | 05:45 AM
JamesC's Avatar
My experience is with the 89-92 (and by extension 93-97) PBR's. Here's a link, however, that might provide the info you require:
https://www.thirdgen.org/forums/brak...S1+rear+brakes
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
kah992
Aug 19, 2015 02:55 PM
Jlanz55
Aug 17, 2015 07:15 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
