bolting up backing plate....
Old Oct 14, 2006 | 01:09 PM
strangladesh's Avatar
Im getting closer to haveing my rear brakes all re-buit but ive run into a problem due to how rusty this backing plate was the bottem to bolts that hold it to the axle broke off and i have threaded pieces stuck in the hole on side has the back part of the bolt sticking out so i might be able to get a wrench or vise griips on it to get it out but the other side is broke off on both sides of the nut, i cant get a drill in their or any thing as it is so tight of a spot...please help me...
Old Oct 14, 2006 | 06:34 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd really like to help (if I can). Slow down and explain. Some punctuation and spelling would be helpful.
JamesC
Old Oct 14, 2006 | 06:46 PM
Ok the self taping factory screws in the bottem of the backing plate broke off.
Im thinking ill have to drop the axle as i can not get a drill up in there. How can i drop the axle and pull it out to get enough room?
Old Oct 15, 2006 | 02:34 PM
JamesC's Avatar
Drum or disc? Backing plate or dust shield?
JamesC
Old Oct 15, 2006 | 09:42 PM
its the backing plate...ive got it taken care of now....is their any thing else i should do to the rear while i have the axles removed and the transfer case taken apart?
Old Oct 16, 2006 | 09:16 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Might as well inspect or replace the bearings and seals, change out the oil in the differential.
Ed
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
