HELP! P*SSED OFF LT1 Rear E-brake
Old Nov 24, 2006 | 05:42 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
I installed a LT1 PBR disc rear into my 91 RS drum car and someone on this wonderful site said to get two Raybestos BC94597 cables for my application.
Well there too long and dont fit the caliper right. Could someone PLEASE give me the part number I do need.
Old Nov 24, 2006 | 08:01 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
That is the correct P/N for your '91 year car..do you have the adjustable cable in the trans tunnel? Can you describe the problem and how it's not hooking up right?
Ed
Old Nov 24, 2006 | 08:05 PM
crrllmich's Avatar
Engine: L03, LS1
The internal cables is just to long. I saw the picture of the way your T-Bar in your tranny tunnel is and mine looks nothing like that.
Old Nov 24, 2006 | 08:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i thought it was 91 Z28 disk brake car Ebrake cables for the LT1 disks? the first design as there are two designs. because 91-92 Z28 cars with disk brakes used the same style rear disk brakes as the LT1 cars...they are the aluminum PBR stuff
Old Nov 24, 2006 | 08:07 PM
crrllmich's Avatar
Engine: L03, LS1
BC94597 is the 91 Z28 e-brake I don't think its adjustable but maybe im just stupid. Anyone got a pic of one?
Old Nov 24, 2006 | 08:12 PM
ebmiller88's Avatar
How much too long? If yours is different than mine then it's correct.
Ed
Old Nov 24, 2006 | 08:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
hmmm thats weird, it should have worked just fine. i thought that part number was for the LS1 rear brake swap..looks the same
Old Nov 24, 2006 | 08:15 PM
crrllmich's Avatar
Engine: L03, LS1
Dunno I am gonna look again tommorow maybe I am stupid but if not then I am gonna exchange for the shorter one and be sure to take lots of pics. Also they would not fit over the axle.
Old Nov 25, 2006 | 04:14 AM
ebmiller88's Avatar
Just in case, they should be run like this seen in post #13:
https://www.thirdgen.org/forums/brak...ighlight=shims
James also has good pics of how to route them and here's my car's cable routing:
http://pg.photos.yahoo.com/ph/tarami...ce.jpg&.src=ph
Ed
Old Nov 25, 2006 | 06:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The length should be 1434 mm (1st design).
JamesC
Old Nov 25, 2006 | 09:32 AM
crrllmich's Avatar
Engine: L03, LS1
Ok so now I need the first design? I am so cunfused lol.
Old Nov 26, 2006 | 05:56 AM
JamesC's Avatar
I used cables from CarQuest (P/N BRK 8788, 1st design, 1434 mm). I had to use a Dremel to slightly enlarge the retangular slot on the caliper end of the cable to make it fit the parking brake lever. Two minutes work.
JamesC
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
