few questions regaurding the bolts and holes on the C5 spindle mod
Old Dec 23, 2006 | 09:59 AM
BOTTLEDZ28's Avatar
Transmission: A4
Ive got a lot of info in front of me pertaining to the mods needed to be done to the spindle in order for the C5 brakes to work but I think some of it may be wrong. this is what I have for the spindle mod
the two holes need to be retapped with a 7/16ths-13 standard thread. Do I need to first drill through these holes to remove the old threads and then use a 7/16ths tap? is that all thatis needed to be done to these holes in preperation for the bracket? If that is correct then I take it that all I need to do is get 4 7/16ths bolts right? If not then is there a standard size bolt and tap you guys are all using that is proven to work?
Also, I take it that the bolts I need for the bracket to abutment are M14-2.0 x 35mm allen head bolts which should be easy to find at either the dealer or a hardware store.
Old Dec 23, 2006 | 11:00 AM
BOTTLEDZ28's Avatar
Transmission: A4
ok did somemore searching and I guess the 7/16" bolt is the best bet since its a standard common size bolt. Now I take it that I shuould get this size bolt with a high thread count since they are stronger right?
Old Dec 23, 2006 | 09:20 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
7/16-14 will be fine and plenty strong enough, easier to locate if you need one as well. Drill a 3/8" hole, tap with 7/16"
I use socket head Allen bolts for the 14mm bolts, the GM factory 14mm bolts will be too long and are about $5 each.
Ed
Old Dec 24, 2006 | 08:35 AM
BOTTLEDZ28's Avatar
Transmission: A4
Ed, thanks for the info. I sentya a PM
Old Jul 25, 2007 | 12:44 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: few questions regaurding the bolts and holes on the C5 spindle mod
Ed, I really need to get in contact with ya. You are the conversion guru and I am lost, sorta. I am trying to aquire sellers for all the parts that I need, but don't know if I am just wasting my time and eventual $. How mush would you charge for C5 front, and LS1 rear. After all is said and done. I have spindles that I can mod but I would like hubs. Thanks for any help. I also e-mailed you at your website. Thanks.
Old Jul 25, 2007 | 08:28 PM
ebmiller88's Avatar
My apologies..I'm getting to PMs as we speak and depending on the work load will be addressing as many as I can get to tonight.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
ZZ3Astro
Aug 13, 2019 12:57 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
lakeffect2
Aug 23, 2015 08:44 AM
