New rotors recommendation
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
You guys, the ride is an 88 IROC with J65 brakes. Somehow, some way, I've managed to warp the front rotors. I'm thinking to just replace the front rotors, wheel bearings and pads all at once.
I'm looking at Raybestos Brutestop rotors and Bendix Titanium pads. Comments? Any alternate recommendations?
Thanks.
Thanks.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
that would be fine, but now is a great time for a brake upgrade! bigbrakeupgrade.com, if the money is available
Car: 1988 Iroc-Z / 1992 RS
Engine: 5.7 TPI / L03 TBI
Transmission: 700r-4 / 700r-4
Axle/Gears: 9 bolt 2.77 posi / 10 bolt 2.73
I'm in the same boat with one warped rotor. Just bought new pads, calipers, rubber hoses. Now the passenger side rotor is warped. What is a good stock size replacement rotor. Ive heard the cheap ones are bad and warp very easy.
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
