stainless steel brake corp.
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
looking through stuff on summit i found this...http://store.summitracing.com/partde...5&autoview=sku
i know ssbc makes good stuff but has anyone used this quick change caliper setup on their car and if so how easy was it to do?
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
for aabout $200 more you can upgrade to LS1 brakes.
http://www.metzcon.com/bigbrake/
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its better to do a ls1 swap. for the fronts you can buy a complete bolt in set from bigbrakeupgrade.com for like 650$ its a much beeter setup
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I looked at those too before I upgraded my fronts to C4s for the same price. Thing is you need a bigger rotor, the LS1s or C4s is $ well spent.
dbrochard
Sep 19, 2015 08:13 PM
