Proportioning Valve
Old Jan 11, 2007 | 09:08 PM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
Proportioning Valve
I switch from a 83 to a 92 brake booster with the new proportioning block. the rear brakes are from a 94 Z they are the larger disc. from experimentation i found that no valve in there works best but the rubber cap blows off and fluid goes everywhere. how can i properly adjust this to get the correct brake pressure for my set up.
Old Jan 15, 2007 | 12:12 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
To be sure you need no valve I would lock the brakes and have a friend watch if and when the rears lock. If the rears lock before the fronts, you NEED a valve. Most likely you will need one.
The issue with fluid shooting out of the M/C is another issue. When hitting the brakes it is normal for a stream of fluid to hit the top cover, but they're shouldn't be any pressure to pop it off. Are the clips on the sides broken off?
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
