Rear disc upgrade questions
I recently swapped a 88 GTA 10 bolt disc brake rear in my 91 RS 5.0L. Do I need to change the proportioning valve or master cylinder? Does anyone make the steel brake lines, already bent, that are on the rear?
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
I tried to find a new steel line that ran along the rear end and could only find them in a complete aftermarket set which was big bucks. I made my own, but you need a double flare kit tool to do the ends and a bender. I had to use the old mounting connector block and ends as I could not locate them at parts stores. As for the MC and Prop. valve, I'm not sure if they are different. Go to your local auto parts and have them check application for both year vehicles.I f the numbers match or are different, well theirs your answer. Hope this helps. Badman
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Ed
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
