what type of calipers are these.
Old Jan 17, 2007 | 03:15 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I was just wondering if i should trash them or sell them. Im not sure what exactly they are from but they are powdercoated silver and look nice. I dont think they are any of the desirable calipers.
Attached Thumbnails what type of calipers are these.-dsc01198.jpg   what type of calipers are these.-dsc01203.jpg
Old Jan 17, 2007 | 03:22 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You're correct. They're the typical iron calipers found on a decade of thirdgens.
JamesC
Old Jan 17, 2007 | 03:29 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
will lt1 brakes bolt on the same brackets as these?
Old Jan 17, 2007 | 03:38 PM
JamesC's Avatar
No.
JamesC
Old Jan 17, 2007 | 05:05 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
will lt1 backing plates and calipers bolt on the axles these calipers came from?
Old Jan 17, 2007 | 06:34 PM
JamesC's Avatar
LT1's and PBR's are essentially the same caliper, so with the proper backing plates, they will bolt up to a disc rear end. Since your car is a 92, there may be some issues with the e-brake cable, which is self-adjusting. You might consider a search for more info.
JamesC
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
bjpotter
Oct 4, 2015 07:48 PM
the_hamturdler
Sep 30, 2015 12:50 PM
