spinning on ice....
Car: 85 TPI IROC-Z
Engine: LB9
Transmission: 700 Bulletproof
Axle/Gears: 3:42
spinning on ice....
OK. I venture my IROC out today in the ice
basically just the neighborhoods are still bad.
The problem I'm having (and I have the same problem with my other camaro) is on Ice when I press the brakes the back wheels still spin... How do i correct this or is it just something I need to learn to live with?
the brakes 'seem' to work fine on dry ground....
basically just the neighborhoods are still bad. The problem I'm having (and I have the same problem with my other camaro) is on Ice when I press the brakes the back wheels still spin... How do i correct this or is it just something I need to learn to live with?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
drums or discs? if they dont lock the brakes are not working right
Car: 1987 Firebird
Engine: 355
I have the same prob, ur rears are either out of adjustment or worn out. Do a rea brake job, and adjust them. I got away with this by putting the car in neutral, but is a safety hazard. Basically if they arent stopping now, they arent stopping on the road, and ur fronts will wear prematurely and could get you into trouble. This is assuming you have drums. Is your brake pedal spongey?
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I haave this problem when my car hasnt warmed up right. Its idling high and the rears are drum so the fronts are locked and the backs are spinning until the car warms up right.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
he has drums 85 iroc...... no disc.... and its because its drums... if he had a stall converter then this problem wouldn't occur..... the car always wanted to "go" at a stop light when stopped... too small of a stall...
Denricci22
Sep 18, 2015 09:02 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
