How to adjust rear disc E-Brake?
Old Jan 24, 2007 | 02:19 PM
ChampionN84's Avatar
Car: 91 Camaro Z28
I rescently installed new e-brake cable on my 85 camaro z28 with stock disc brakes in the rear. One cable had little slack and the other had alot how to you adjust the e-brake on these cars?
Old Jan 24, 2007 | 02:49 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Underneath car in center rear above driveshaft is where the cables connect. A single nut on threaded rod is used to tighten up slack in cables. Tighten until the e-brake lever(part with the weights on it) on the caliper just starts to move off the stop on the caliper. Then use emergency brake every time you park car. Constant use of e-brake keeps the rotating assy. in the caliper adjused and free.Badman
Old Jan 24, 2007 | 03:07 PM
Car: 91 Camaro Z28
So even if the cable are not lineing up it will fix itself with use of the brake? Correct...
Old Jan 24, 2007 | 04:16 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
No, I have seen some aftermarket cables that are a little too long or too short! Did you compare the old ones to the new ones? If they are not the same as the originals it may be causing the slack on the one side. Also check and make sure the new cable ends are in the adjuster catch and make sure the cables are riding in the guides under the car.Badman
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
