brake probs
Old Jan 26, 2007 | 10:20 AM
monoply6's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
brake probs
hi all coming home from work when i braked from 70 to 30 the sterring wheel started to shake ,under light brakeing seems fine it did not pull to any side while brakeing i put new pads in and checked them pass side ok drive side pads have a little movement could this be calliper issue or the brake hose ,callipers are quite dear over here so hope its the hose
Old Jan 26, 2007 | 04:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
rotors could be warped
Old Jan 27, 2007 | 07:07 AM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
not the rotors ive put new set on ,wheres the best place to get brakelines and callipers from the states
Old Jan 27, 2007 | 03:18 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Do some troubleshooting before you throw parts at the problem. Steering wheel shimmy is gonna come from warped rotors or worn steering parts, loose/bad wheel bearings. Check everything out to pinpoint your problem, you might save yourself some cash.
I just picked up Delco brake parts for decent prices from the link below.
http://www.rockauto.com/
Corky
Old Jan 27, 2007 | 09:11 PM
SmokeDiver85T/A's Avatar
shake
I agree, it's not unheard of to get warped rotors new in the box.
Adam
Old Jan 28, 2007 | 02:56 AM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
well ill get them checked out but why would the driver side pads move in the caliper my wife pressed brake pedal and caliper did not push the pads on to the disc thanks for top link corky
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
89 formula TPI
Sep 8, 2015 08:00 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
