'89 RS w/drum converting to disc rear (non PBR)
Old Feb 4, 2007 | 11:20 AM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
I am at the point of information overload, I have just read about every article in the search critearia.
I am confused now, I have a '89 RS w/rear drum, I came into possesion of a disc rear from a pre '89 era 3rd. gen. it is a 10 bolt, has an auburn diff, 373 gears, moser axels, new rotors and new pads. I heard some of the down falls of the iron caliper rears but this is what I have.
1st will the proportion mod work? or do I get the 1LE proportion valve? or 3rd. run the Wilwood adjustible inline with my o/e? if I do the 3rd option what thread size nuts do I look for so the wilwood one to work properly?
I really want to put this on.
according to the door production date is 1/89
HELP!
Old Feb 4, 2007 | 11:45 AM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
you will need to change the proportioning valve to one off a third gen with 4 wheel disc
Old Feb 4, 2007 | 11:49 AM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
but would I need to get one from a pre 89? are the thread sizes different or the same?
Old Feb 4, 2007 | 01:48 PM
Boosted_SS's Avatar
Engine: 383 TPI
shouldn't matter. personally i would get one for the year of the car you have so you know it will be a direct bolt on.
Old Feb 5, 2007 | 05:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes. The thread sizes are different. IIRC, they changed in 89. By the way, many people complain about the iron calipers, but mine functioned well (with the use of the e-brake). The swap to PBR's, however, is simple:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Feb 5, 2007 | 06:03 PM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
thanks people for the replies, after some thoughts and suggestions I am going to try the wilwood method.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
