9 bolt disc barake conversion in drum brake car questions
Old Feb 20, 2007 | 04:11 PM
camaro8tysvn's Avatar
Car: 87 camaro
Engine: 355ci
Transmission: richmond 5 speed
i have a 87 camaro that as orignially a v6 10 bolt drum brake rear. i just bought a 9 bolt posi with disc brakes. can i put the drum brake set up from my 10 bolt on it or do i have to set up my car with the discs and if i set my car up with discs what else do i have to do for the conversion. its an 88 9 bolt
Old Feb 20, 2007 | 05:49 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
You cannot use the drums on the 9 bolt. Hopefully, you have the calipers too?
There are many posts related to this swap.
You will need the correct porportioning valve for proper front / rear braking bias. Check with your GM parts dealer to see if the master cylinder is compatible with the year of 9 bolt rear end that you have. Also, you'll probably need new e-brake cables.
Good luck
Old Feb 20, 2007 | 07:17 PM
Car: 87 camaro
Engine: 355ci
could i get an adjustable porpotioning valve like from jegs and bypass the stock porpotioning valve
Old Feb 20, 2007 | 08:40 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
yeah, you can bypass the stock one and use the jeg's unit. i replaced my worn 9 bolt posi disc with a 3.73 10 bolt locker drum, and i didn't bother to change the valve. no complaints, pedal feels fine and stops good and straight.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
