So i found a Leak...
Car: 04 Chevy Silverado 1500
Engine: V6
Axle/Gears: Stock
Its comeing off one of the lines that comes from the Master Cyl. I have a Brake Light on. Should i just try to Tighten it or what should i do, my pedel also fells like a sponge. Also, it has a New Master Cyl. Thanks.
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
You can try to tighten it, I suspect with a new M/C it just didn't get tight enough. If it is tight the line might have a crack in the flare then it will need to be replaced. Either way you will need to bleed the brakes, that should firm up your pedal.
Fix the leak first.
Fix the leak first.
Engine: V6
Axle/Gears: Stock
Its the metal one that screws into the M/C. I am gonna call around and see if a brake shop can look at it.
Abubaca
Nov 5, 2016 12:22 PM
rudolphschenker
Sep 4, 2015 02:41 AM
