swapping 9bolt disc to drum 10 bolt?
Old Mar 17, 2007 | 02:05 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
I recently aquired another 9bolt disc rearend and really don`t want to spend the money to get 3.73 gears put in when they are 400+ for the gear alone. And i already have 3.73 posi now in my 10 bolt. So has anyone swapped the 9 bolt brakes to there disc drum 10 bolt and been sucsessful?
Old Mar 18, 2007 | 01:19 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The disc brakes on a 9-bolt are the same as the same year 10-bolt, so they will bolt on (except the backing plates are different). However, you're converting from drums to discs so its a bit tricky. There is either a tech article or a forum post on how to convert drums to discs, so a little searching will find it.
hectre13
Dec 11, 2023 08:14 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
