Leaky Master Cylinder Reservoir! Help!
Old Mar 28, 2007 | 07:21 AM
AUSSIROC's Avatar
Car: 1999 subaru forester GT (urgh)
Engine: ej20 turbo
Transmission: 5speed
Axle/Gears: 4.11:1 awd
Hey all,
The master cylinder leaks where the reservoir connects to it on top. The lid and gasket are in good shape. Is there a replaceable o-ring or something that fits between the aluminium master cylinder and the plastic reservoir to fix this? (hopefully it isn't press-fit - i dont wanna fork out for a reco mc). I have just repainted the engine bay, and don't want to wreck the paint on the wheel well like it did before.
Anyone know of any replacement o-rings / alternatives????
Old Mar 28, 2007 | 03:55 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Re: Leaky Master Cylinder Reservoir! Help!
just get a remanufactured one, there cheap and u can just bench bleed it
I think u could also get a rebuild kit, not sure
good luck!
Old Mar 29, 2007 | 02:46 AM
AUSSIROC's Avatar
Engine: ej20 turbo
Sounds good thanks for the tip
Old Mar 29, 2007 | 07:23 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I found a rebuilt MC from O'Reilly's (~$20) came with a new reservoir and was less expensive than buying a replacement reservoir alone.
Anyway the reservoir just presses in and the seals hold it. You may pull yours apart to see what the problem is. A rebuild kit may come with new seals if that's all you need.
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
