MC and Prop Valve Replacment
Old Apr 5, 2007 | 05:58 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I did a search but could not find the answer. When replacing both the master cylinder and prop valve, do you siphon the brake fluid from the master cylinder before removing? I just don't want brake fluid spilling on my engine compartment.
Old Apr 5, 2007 | 08:01 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Re: MC and Prop Valve Replacment
I would like to know this also. I figure from common sense that your right ...it makes sense to siphon it out.
Old Apr 5, 2007 | 09:27 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
If you leave the cap on and remove the MC it will help. use a shop towel on the connections will minimize the amount of fluid you lose. If some does get someplace you don't want it don't waste any time cleaning it.
Old Apr 13, 2007 | 11:09 PM
95foxbigblock's Avatar
watch your paint
gta90
Sep 15, 2015 04:00 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
NBrehm
Aug 25, 2015 11:49 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
