Sticking left rear caliper
Old Apr 5, 2007 | 11:52 PM
raven0840's Avatar
Car: '83 Camaro Z-28
Engine: 350 Crossfire
Axle/Gears: 3.23 posi
Just swapped my drum axle for a 9 bolt posi disc. Haven't gotten around to redoing prop valve yet, but the left rear caliper isn't releasing completely. Apparently a bad hose can cause this problem but that side doesn't use a hose. I thought it might be the e-brake but the problem got significantly worse after I bled the lines (i.e., unrelated to the e-brake). The caliper is causing enough friction to smoke considerably after a short (couple of blocks) drive. Autozone want $65 per caliper, before I throw another $120 at this, any ideas as to what might cause that kind of problem? Thanks!
Old Apr 6, 2007 | 02:21 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Sticking left rear caliper
if the line is not blocked then the caliper is sticking and a rebuild kit must be used. They are cheap if you do it yourself, or you can buy the lifetime warranty ones like I did a long time ago.
Old Apr 6, 2007 | 02:50 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
my left rear did that once.. the was soo much friction that it was smoking the tire on the rim.. and burnt all the paint off the rotor.. after a good bleed, it works like a charm..
1992 Trans Am
May 10, 2023 07:19 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Bert87
Aug 23, 2015 03:50 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
