What r good front cross drilled rotors for a camaro?
Old Apr 6, 2007 | 10:58 AM
ino's Avatar
ino
Car: 87 firebird
The car is a 91 z28. Looking to get crossed drilled or slotted. Where is a good place to get them? Is roto-tech a good brand?
Old Apr 6, 2007 | 11:01 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: What r good front cross drilled rotors for a camaro?
Jegs.com might have what you are looking for.
Old Apr 6, 2007 | 12:56 PM
HPE's Avatar
HPE
Stillen. they make good quality rotors and very good compound brakepads for performance noise free daily street use _ I can not preach enough how good there brake pad compound is- You just gotta trust me on that one, I have used them for years and if I could get a set made that would ork on my Camaro custom brake I would be running the Stillen MetalMatrix compound rright now.Just so you know what brakes I have- I bult them myself with Wilwwood 6 pistion calipers and 13" rotors.Do not use Powerstop rotors, I have tried them in the past and the metal quality is junk. I still to this day use Stillen x-drilled rotors and pads on my daily worktruck that carries very heavy loads of marble and stone. They are not cracked and have been on there for about 10 years.
Old Apr 7, 2007 | 10:06 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I was reading some of your posts about those pads i wish i had read them sooner. I just installed 1LEs up front with a stock type semi metallic pad. they work great when cold so far. The poor cold braking has always turned me away from the so called performance pads.
Old Apr 8, 2007 | 08:26 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
anyone have opinions on the Summit Extreme Performance Cross-Drilled and Slotted Brake Rotors for 59.99?
Old Apr 8, 2007 | 11:33 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I bought a complete set of fronts and rears from PowerSlot. The fronts were C5s an the rears were LS1s. They were 150 total from ebay brand new.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
db057
Aug 22, 2015 08:17 PM
